Activity › Forums › Apple Final Cut Pro Legacy › How do I Batch re-digitize video only?
Posted by Paul Huppe on September 22, 2005 at 7:05 pmI’m moving from offline to online on a project and need to batch re-dig at hi-res. But I don’t want to re-dig the audio, as it’s perfect the way it is.
I’ve tried through Media Manager; I’ve tried selecting video on the timeline; I’ve tried un-linking the clips and then selecting video. Nothing works.
Suggestions?
Paul
Bill replied 21 years ago 5 Members · 9 Replies -
John Pale
September 22, 2005 at 7:14 pmDuplicate your sequence. Delete all the audio clips from the duplicate. Media Manage that sequence.
Paul Huppe
September 22, 2005 at 7:17 pmThanks!
I guess I was expecting a more practical way to do this. Perhaps FCP can take note and tackle this for the next release?
Bill
September 22, 2005 at 7:36 pmhave you tried creating a bin with the used material and with those clip offline you should be able to into clip settings and adjust accordingly. its a long and tedious process. in previous versions form 5 you could do it at the bin level. Just curious though, audio doesn’t take up all that much room. So why the need to dump it?
“Reach for the sky cause tomorrow may never come”
-Mike Ness
Jeremy Garchow
September 22, 2005 at 7:46 pmYOu need to unlink your video and audio in your ‘offline’ sequence, media manage, then select and relink the audio with the original files, then batch capture the new video.
Jeremy
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
Shane Ross
September 23, 2005 at 3:15 amA more PRACTICAL way? That sounds like a very easy and viable way. That is how I online using an Avid. Duplicate the sequence, remove the audio tracks, decompose (a feature I miss in FCP) and batch digitize. Then add your aduio back to the ONLINE cut when done.
Presto!
Paul Huppe
September 23, 2005 at 12:16 pmMainly because I’m working with tapes that don’t have bars and tone on them (thanks, cameraguy!) I’ve already adjusted all the audio. If I re-dig, My mix depends on where my levels are set on the deck. I’d rather bypass it altogether, frankly.
I’m a Media100 guy, and on that platform you can select to re-dig audio or not at the click of a button. Simple, effective. Thought there might be a similar feature on FCP. Maybe next update?
John Pale
September 23, 2005 at 12:19 pmYou do have a decompose-like feature…select your sequence then
Tools/Create Master Clips
a bin is created with master clips for every clip in the sequence. This is very similar to the decompose function in Avid.
Bill
September 23, 2005 at 2:02 pmgood answer…. makes sense i was just curious on why. best of luck on your process.
-Mike Ness
