Activity › Forums › Apple Final Cut Pro Legacy › How do I Apply Color Correction to Entire Sequence
Posted by Anderson Black on February 28, 2008 at 5:01 pmI want to apply color correction to entire sequence without having to copy and paste the filter into every individual clip on the timeline.
In Avid I can easily do this by putting the filter on the track above my clips.
How is this achieved in FCP? thanks.
David Roth weiss replied 18 years, 6 months ago 5 Members · 8 Replies -
Tom Wolsky
February 28, 2008 at 5:23 pmThe nest the sequence and apply the filter to the nest. Or copy and paste attributes.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
Miklos Philips
February 28, 2008 at 6:05 pmEasy in FCP as well. If you want to apply the SAME color correction settings from one clip to the rest of the sequence just open the first clip in the viewer and go to the filters tab where you have your final color correction settings.
2.) go back to you timeline and select all the other clips (make them highlighted)
3.) drag the filter to the selected clips – any one of them – and the filter will be applied to ALL the selected clips. When you drag the filter on all the clips they will change highlight letting you know that this filter will be applied to all the clips.
Point Zero Pictures
<https://www.pointzeropictures.com> -
Anderson Black
February 28, 2008 at 6:36 pmTom thanks for the tip but I don’t even know how to nest 🙁
Miklos thanks, yeah it’s easy. It works!!!
Wish I had posted this before I copied and pasted them individually.
David Roth weiss
February 28, 2008 at 7:05 pm[Chinedu Ezeike] “Wish I had posted this before I copied and pasted them individually.”
Ever tried using the online manual? If you click on “Help” its right there 24 hours a day, 7 days a week.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Matt Devino
February 28, 2008 at 7:48 pmAnother easy way to do it is to add the color correction filter to the first clip in your timeline, make the adjustments you need, then click on the clip so it is highlighted in your timeline and hit copy, then lasso or shift click the rest of the clips in your timeline so they are highlighted, right click on any one of them and select “paste attributes” and choose filters. This will apply the color corrector filter to every clip in the timeline with the adjustments intact. Of course if you have any other filters on the first clip they will be applied as well, so make sure the only filter on that clip is the color corrector if you do it this way.
Anderson Black
February 28, 2008 at 8:28 pmHey David thanks for the tip. I guess the thousands of people that post on this forum including you, didn’t find what they were looking for in the online help (in my case, I probably searched with the wrong keyword).
But thanks for your help though. Your usefulness doesn’t escape me.
Anderson Black
February 28, 2008 at 8:30 pmThanks a lot Matt, I really appreciate all the tips. I knew there was a very easy way to do this.
David Roth weiss
February 28, 2008 at 9:56 pm[Chinedu Ezeike] “But thanks for your help though.”
Glad to be of assistance.
David Roth Weiss
Director/Editor
