Activity Forums Adobe After Effects how do i animate emitter position in trapcode particular?
  • how do i animate emitter position in trapcode particular?
    Posted by Soojung Kwon on November 7, 2008 at 3:25 am
    hi, i know this must be something so basic, but i’ll appreciate your help since i’m new to this whole thing..
    using trapcode particular, i’m trying to make a custom shape emitting from the tail of a dog as it is moving. how do i make the emitter point position so that it moves along with the tail?
    Paul Conigliaro replied 17 years, 10 months ago 3 Members · 2 Replies
  • Jan Sherlink
    November 7, 2008 at 7:04 am
    I can’t imagine that you can track the dog’s tail,
    so you’ll need to keyframe it by hand !
    cya,
    Jan
  • Paul Conigliaro
    November 7, 2008 at 2:59 pm
    If you can’t track it, you may need to keyframe it manually. One thing that might help you is to attach the emitter to a light layer. This will make it much easier to visualize where the emitter is and which direction it’s pointing.
