Activity Forums Adobe After Effects How do I animate a 2D character?
  • How do I animate a 2D character?
    Posted by Matt Plonsker on March 31, 2009 at 1:12 am
    I’m really new to adobe after effects so if this is blatantly obvious I apologize. I drew some characters on paper in their individual parts (i.e. seperate head, arms, chest..) and I was trying to animate them. It seemed like it was going to take forever if I had to animate each part individually for every movement. There was another kid in my class who set up a matrix (i think?) that allowed him to set all of the pivot points. He could then just adjust the body using keyframes to make the animation much faster.
    If anyone knows how to do this please let me know.
    Thanks.
    Mike Roberts replied 17 years, 1 month ago 4 Members · 3 Replies
  • Christopher Mcnamara
    March 31, 2009 at 2:33 am
    HI Matt,
    I’m in the middle of something and noticed your post. Here is a good link but the feature in question is only available in After Effects CS3.
    Check this out;
    https://www.metacafe.com/watch/885847/puppet_tool_in_adobe_after_effects_cs3/
    Cheers
    Chris (your prof….)
  • Filip Vandueren
    March 31, 2009 at 2:41 am
    the puppet tool works well for bending single layers by putting and moving ‘pins’
    for multi-layer characters, use the “pan-behind” tool (look it up in the manual), to position the anchorpoint where the rotation should be, then use parenting to create a “tree-structure”
    when a parent rotates (or moces, scales), all of it’s children follow.
    for example:
    R foot is parented to R lower leg
    R lower leg is parented to R upper leg
    R upper leg is parented to pelvis
    R Hand is parented to R lower arm
    R lower arm is parented to R upper arm
    R upper arm is parented to upper body
    upper body is parented to pelvis
    etc.
    the pelvis would be the best choice to be the ‘über-parent’
    you could combine this with puppet-anims on some layers.
  • Mike Roberts
    March 31, 2009 at 4:29 am
    Hey,
    This is about as awesome as it gets… THANKS DAN!!!
    https://www.motionscript.com/expressions-lab-ae65/ik.html
