Activity › Forums › Adobe After Effects › How do I add gradient to multiple letters
Posted by Roberts Adi on January 26, 2021 at 3:32 pmGuys please how do I add gradient to multiple letters without editing one by one
thanks
Kevin Camp replied 5 years, 7 months ago 4 Members · 3 Replies -
Dave Baum
January 26, 2021 at 4:01 pmAssuming you want to use the same gradient on all your letters, then I would do it by using the text as an alpha matte. So type whatever text you want on its own layer. Then on a new layer, create the gradient you would like to use.
Place the gradient layer under the text layer, and then from the timeline, make sure you can see the Track matte column, and then select your text layer as the track matte to display the gradient through. Attached screenshot might help
Jim Krause
January 26, 2021 at 4:06 pmSelect the layer and then look under Effects -> Generate -> Gradient Ramp. You can even animate it (much better than a plain old gradient.
Kevin Camp
January 26, 2021 at 6:10 pmThere’s also Layer Styles… right-click the text layer and choose Layer Styles > Gradient Overlay.
Twirl down the Gradient Overlay property and change settings as needed.
