Activity Forums Adobe After Effects How do I add a camera click to sequence of stills?
  • How do I add a camera click to sequence of stills?
    Posted by Rob Such on April 14, 2012 at 4:35 am
    Anyone know how I can add a camera shutter click, recorded as a wav file, to a sequence of stills? Just wondering if there’s a quick way to do it, rather than having to duplicate the sound and manually add it to each change in still image. I imported the sequence and set the frame rate to 5fps.
    Thanks.
    Benjamin Ausmith replied 14 years, 5 months ago 3 Members · 8 Replies
  • 8 Replies
  • Juan Salvo
    April 14, 2012 at 4:49 am
    Render out the video then add the camera click in a video editor. Will be much easier. Just copy and paste along the sequence as needed.
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Rob Such
    April 14, 2012 at 5:01 am
    Thanks. I asked about this in a Premiere Pro forum. Was told this sort of stuff would be done in AE! I was thinking if I could select all the stills in the timeline and add a default transition, I could set the camera click as default audio transition. Could I make the camera click into an audio transition and set it as default?
  • Juan Salvo
    April 14, 2012 at 6:00 am
    No. But you can skip edit to edit and paste in the sound effect.
  • Rob Such
    April 14, 2012 at 6:21 am
    Er, ‘skip edit to edit’? What does that mean?
  • Juan Salvo
    April 14, 2012 at 9:51 am
    Don’t know off hand what the keyboard shortcut is in premiere. But in fcp you press the down arrow and it takes you to the next cut in the sequence.
  • Rob Such
    April 14, 2012 at 12:01 pm
    Thanks. Found out the fn+down arrow does that. Any idea how to get the camera shutter audio click to centre over the still change? It keeps snapping to the clip, either start or end. I can’t get it to sit over the change in still image in the timeline.
  • Rob Such
    April 15, 2012 at 5:15 am
    Hi, yes, that’s it. It works well if you have a short burst of still images taken as you move through a scene. The only thing is I can’t position the camera click over the change in still image in the timeline. It either snaps to the beginning or the end of the image/clip. And the camera shutter sound also slows down as well because I set the image sequence to 5 pfs.
  • Benjamin Ausmith
    April 17, 2012 at 7:14 pm
    Pressing ‘s’ turns off snapping in Premiere.
