Activity › Forums › Adobe After Effects › How do I achive this effect in AE CS6
  • John Cuevas
    February 10, 2014 at 4:29 pm
    There are a few things happening there that make that effective. On the beat, video slows down. That could be created using using a time effect(timewarp) or just time remapping the layer.
    Next the video is duplicated twice and masked and stacked above the original layer. Position keyframes move the 2 upper layers into place. The opacity of these layers isn’t 100%, and with a couple of keyframes they fade quickly out, revealing back the original image.
    I made a very simplified version of the effect to illustrate the technique. 7116_pipandopacityfadefolder.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Philip Jacob
    February 17, 2014 at 4:27 am
    Hello John, You are awesome. I truly appreciated your time and sample you shared with me. This is exactly I was looking for. I think this may be a built in effect in final cut pro. Thanks so much.
