Activity Forums Apple Final Cut Pro Legacy How do I achieve this?
  • David Battistella
    May 13, 2010 at 3:00 pm
    Pick the frame you want to freeze on.
    Hit match frame or hit the f key.
    Go to the MODIFY menu and select MAKE FREEZE FRAME
    overwrite edit the freeze frame at the same place in the timeline ( 2 seconds maybe)
    Add the dissolve to the freeze frame.
    David
    Peace
  • Mark Suszko
    Top of your screen, in the drop-down menus, Modify>Freeze frame. In the left hand canvas, upper left numerical box, type in a duration, say, 30 frames. Hit “Enter”. Now you can drag and drop that still onto the timeline right next to the last frame, and apply a dissolve to black. Stretch the lengths of the dissolve adn the freeze frame piece to taste. I usually put a slug of black next to the last shot to dissolve to.
  • Charlee Núñez
    May 13, 2010 at 3:55 pm
    Awesome! Thanks, guys.
  • Sascha Engel
    May 18, 2010 at 3:39 pm
    just make sure, your footage is progressive – if not, make that part first progressive by De-Interlacing, then do what’s mentioned above. If not, you will freeze frame a picture with Interlaced lines.
  • Charlee Núñez
    May 20, 2010 at 12:30 pm
    Thanks for the tip!
