Activity › Forums › Web Design (WordPress, Joomla, etc.) › How difficult is it to set up a client FTP section on a web site?
  • How difficult is it to set up a client FTP section on a web site?
    Posted by Camogr3 on May 3, 2005 at 4:52 pm
    I’m new to Dreamweaver and didn’t see too much reguarding this issue. Is this something I do with my web host or set it up in Dreamweaver?
    I’m not even sure where to start. Any advice would be great.
    Camogr
    Curtis Thompson replied 21 years, 4 months ago 2 Members · 1 Reply
  • Curtis Thompson
    May 3, 2005 at 5:06 pm
    hello…
    i’ve written a free tool for this in the past – it requires php and the ability for safe mode to be disabled in said php (check with your isp), but if you support both (the latter is not so much required for running but for clients to be able to upload files to your server via the tool – it’s a security thing) then you are free to use it:
    https://www.sitruc.com/downloads/php_client_area.zip
    it’s got an install and suggestions for seeing if you can run it in the _INSTALL.txt file…
    sitruc
