Activity › Forums › Adobe After Effects › How day do dat?
How day do dat?
Posted by Malcolm Desoto on July 16, 2007 at 5:31 pmIs this a physical effect? A mixture of both physical effects and some AE work?
Jeremy Garchow replied 19 years, 2 months ago 6 Members · 10 Replies -
Steve Morris
July 16, 2007 at 5:55 pmI only watched the first min. I assume you are referring to the light streaks. All of the lighting effects were done in post. I saw nothing that looked “physical”. These effects could be done with a stroke, or 3D stroke in AE. They could also be created with a particle emitter such as Particular.
David Franklin
July 16, 2007 at 6:02 pmMaybe, but I wouldn’t be quite so certain. All the live action looks like it was shot stop-motion, which would make using practical lighting techniques in-camera a plausible way to go.
And then there’s the fact that this is becoming a popular technique. Read the following exchange, and the articles linked to within…
https://forums.creativecow.net/cgi-bin/new_read_thread.cgi?forumid=2&postid=910639&univpostid=910636
Nick Berrisford
July 16, 2007 at 6:31 pmI am sure this was done the same way the new Sprint (?) ads were done (i’ll see if I can dig up that link). It’s stop motion with people using small colored pen lights etc. to create the shapes and “move” them around in space. There may be some post work to clean it up and comp it, but it’s good old fashion long exposure stills with a moving light source. You COULD do it with Particular. But it wouldn’t have that organic look that the video does. Though it would be easier to make your shapes, you’d need to tweak it to give a real organic feel.
Malcolm Desoto
July 16, 2007 at 6:31 pmThanks for the link.
I doubt it was done in post alone. I know something similar could be created with a praticl lighting effect, but if you look closely, You can see the light reflecting off various surfaces.
Nick Berrisford
July 16, 2007 at 6:46 pmHere’s specific about the Sprint Ads. One is CG, but the cooler one, that looks just like that video is stop motion with post work pulling it all together:
There’s also some stuff and links anout light painting here, along with the ads and that music video:
https://www.davidairey.com/light-drawing-and-light-writing/
Steve Morris
July 16, 2007 at 6:59 pmI went back and took a closer look. The monitor at my office is very dark and does not show a lot of detail in the darker areas. I can now see how they used colored LED lights.
Malcolm Desoto
July 16, 2007 at 7:05 pmThanks for the link Nick. I think I’m going to play around with the effect and see if I Can produce something close.
Jeremy Garchow
July 17, 2007 at 3:41 amIf you check out the blurb on youtube, it says if you read the August issue of American Cinematographer, you can find out how to make your own light animations.
https://www.youtube.com/watch?v=_lHLSXHad0Y
Jeremy
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Mike Procunier
July 17, 2007 at 1:13 pmYou can see people holding the flashlights in many of the shots… take a look at the very last shot.
Jeremy Garchow
July 18, 2007 at 5:49 pmYou can also see very blurry images behind the animations, suggesting that there are people holding lights in the photos.
