Activity Forums AJA Video Systems How could I format my Compact Flash cards leaving it as factory state?
  • How could I format my Compact Flash cards leaving it as factory state?
    Posted by Daniel Tundis on June 1, 2012 at 7:29 pm
    Whenever I plug my in one of my SanDisk Extreme 90MB/s Compact flash cards into my Aja Ki-Pro Mini it will only recognize my the card as unformatted media. When I try to format those cards I get stuck at the formatting window. I am looking for a driver or utility to restore my CF cards.
    Notes: This is not happening with all of my CF cards, only a few. The only compact flash cards that are being effected by this were used in a sound devices were used in a Sound Devices Pix 240. I can see media that still remains on the cards when I use a reader on my MacBook.
    Vince Gaffney replied 14 years, 2 months ago 4 Members · 4 Replies
  • Jeremy Garchow
    June 1, 2012 at 8:13 pm
    Have you tried formatting on your Mac to HFS+ using disk utility, and then formatting in the KiPro?
  • Matt Mayer
    June 2, 2012 at 9:58 pm
    PIX Recorders format the cards as UDF. IIRC, KiProMini formats as FAT32. Both formats are Mac/PC compatible.
    You will need to reformat the cards in the recorder before using them in that recorder.
    —Matt
  • Jeremy Garchow
    June 2, 2012 at 10:31 pm
    KiPro is hfs+ actually.
    I’d try using disk utility to format the card first, then use KiPro.
  • Vince Gaffney
    June 18, 2012 at 2:51 pm
    I just went therough the same thing. Nikon formatted CF cards wouldn’t re-format in KiPro mini. I formatted them in Disk Utility using Mac OS extended. (not journaled) They work fine now.
