Activity Forums Apple Final Cut Pro Legacy how connect dvcam deck to macbook pro?
  • how connect dvcam deck to macbook pro?
    Posted by Rod Minott on March 12, 2008 at 6:49 am
    I’m new to FCP, and video editing. I plan to edit using a macbook pro. How can I ingest dvcam video from my Sony DSR-2000 deck to the macbook pro? I don’t see a firewire connector on the deck. Any advice would be greatly appreciated. Thanks.
    Rod Minott replied 18 years, 5 months ago 7 Members · 11 Replies
  • 11 Replies
  • Paul Johnson
    March 12, 2008 at 7:18 am
    You’ll need a firewire based capture device. I use the AJA Io LA. If you are just doing dvcam the Io LA will be sufficient but if you want to expand to HD in the future you can take a look at the Io HD. There might be cheaper solutions but I only use AJA, just my preference.
    If you use the Io LA or Io HD you’ll also need to run your external hard drive off of a SATA or Firewire card in your express slot. The Io LA/HD needs to be the only device attached to the firewire bus, thus the reason you need to run your hard drive off of another bus.
    You can check both of them out here:
    https://www.aja.com/html/products_Io.html
    Good luck,
    Billy Johnson
    “Blind respect for authority is the greatest enemy of truth.”
    –Albert Einstein
  • Petteri Evilampi
    March 12, 2008 at 8:48 am
    The easiest and the cheapiest way is to get a deck with a firerwire connector.
  • Tom Wolsky
    March 12, 2008 at 9:55 am
    A DSR-2000 has a FireWire port. It’s probably on the back of the machine with the rest of the I/O.
    Input and Output Connectors
    SDI Video- BNC (x 2 input, 3 output)
    SDTI- BNC (x 1 input, 1 output)
    Fire Wire- 6-Pin (x 1)
    S-Video- 4-Pin (x 1 input, 1 output)
    Composite Video- BNC (x 2 input, 3 output)
    Reference Video- BNC (x 2 input, 1 output)
    Timecode- BNC (x 1 input, 1 output)
    Analog Audio- XLR (x 4 input, 4 output)
    AES/EBU Audio- BNC (x 2 input, 2 output)
    Monitor Audio- 1/4-Inch Phono (x 1 output)
    RS-422- 9-Pin (x 1)
    RS-232C- 9-Pin (x 1)
    Remote Control Panel- 15-Pin (x 1)
    Video Control- 15-Pin (x 1)
    Headphone- 1/4-Inch Phono (x 1)
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Rod Minott
    March 12, 2008 at 4:45 pm
    Thanks! This is extremely helpful.
  • Rod Minott
    March 12, 2008 at 4:56 pm
    Hi Tom,
    Unfortunately, my dsr 2000 does not have a firewire connector. i might have an older model than the one you’re referring to. thanks.
  • Jeff Carpenter
    March 12, 2008 at 5:20 pm
    https://www.roscorrentals.com/equipment_specifications/Sony%20DSR-2000.pdf
    Go down to page 5. Your deck doesn’t look like that one? What’s in the upper-right corner of yours? A blank spot?
    I’m just curious because I’ve never heard of a DV or DVCAM deck without firewire.
  • Rod Minott
    March 12, 2008 at 5:38 pm
    Thanks for the brochure. I checked the back of my deck again. You’re correct. There is a spot that will take the firewire, but looks like I never had the optional DSBK-190 ilink installed. It’s just blank with a plate covering the outlet. I bought this deck back in 2001 and overlooked having the firewire included. Thanks again for following up with me on this.
  • Stuart Allman
    March 12, 2008 at 6:33 pm
    Rod,
    I realize that this may not be much help in your immediate situation, but ror a little bit more than an AJA box I have a nearly new Sony HVR-M15U deck for sale. It handles DVCAM and definitely comes with firewire. Give me a call if you’re interested. (858) 655-5767.
    Stuart
  • Rod Minott
    March 12, 2008 at 9:13 pm
    Hi Stuart,
    Thanks for your offer. I think I’ll stick with my current deck and will find a solution using it. Again, thanks.
  • Jim Carswell
    March 12, 2008 at 10:39 pm
    Rod,
    Where are you located?
    Jim
    Jim Carswell
    Spyhop Productions, Inc.
    Savannah, GA
    http://www.spyhopproductions.com
