Activity Forums Apple Final Cut Pro How come some of my media are references/alias?
  • How come some of my media are references/alias?
    Posted by Seth Marshall on August 26, 2013 at 3:40 pm
    Having a real hard time with FCX. I am noticing on a current project from a single import session, some of my media was copied into my events “original media” folder while others are just reference clips (alias’). I asked it to “copy files”.
    How can I make the reference clips become the full clips as intended?
    Bret Williams replied 13 years ago 3 Members · 3 Replies
  • Ronny Courtens
    August 26, 2013 at 4:40 pm
    Select your Event and choose File > Organize Event Files.
    This will replace the reference files with the actual source media files.
    – Ronny
  • Seth Marshall
    August 26, 2013 at 8:30 pm
    That worked! Thanks Ronny.
    Except for some reason it appears my “Background Tasks” monitor hangs when importing around 53%. In this case it was stuck on 53% even though in the original media folder I see all the alias’d media was correctly replaced by original footage. After restarting my background tasks monitor showed no activity.
    It is common to find it freeze like that?
  • Bret Williams
    August 26, 2013 at 8:55 pm
    If you were still importing you probably shouldn’t have hit the organize media files. It was just using aliases until it was all imported/transcoded. But I have seen the monitor hang, especially on export to weird codecs like WMV, and the import / export was just fine. If all your media is imported and ok I wouldn’t worry about it.
