Activity Forums Adobe After Effects Expressions How can you stop an expression linked to keyframes?
  • How can you stop an expression linked to keyframes?
    Posted by Daniel Haskett on November 14, 2007 at 1:31 am
    Hi there
    ive got a brush position for write on linked to the position of another layer so it can follow this layer.
    however i want it stop half way through so it doesnt copy all the keyframes and just freezes? is this possible? i know i can precompose the layer and then time remap and then freeze it from a certain frame, just wondered if there was a way to do with expressions?
    cheers
    dan
    Dan Ebberts
    replied 18 years, 10 months ago
    3 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    November 14, 2007 at 3:18 am
    Like this:
    stopTime = 2;
    t = Math.min(stopTime,time);
    thisComp.layer(“Layer 1”).transform.position.valueAtTime(t)
    Or, you could do it with a marker, like this:
    stopTime = marker.key(1).time;
    Dan
  • Mike Clasby
    November 14, 2007 at 3:27 am
    Here’s a nifty Dan expression for starting and stopping an expression at a given frame:
    startFrame = 0;
    stopFrame = 241;
    if (time >= framesToTime(startFrame) && time < framesToTime(stopFrame)){ //your expression goes here }else{ value } Set startFrame and endFrame as needed.
  • Mike Clasby
    November 14, 2007 at 3:29 am
    Ooops, didn’t see you Dan. It takes me longer to look stuff up. Oh, well, more options are good, I guess.
  • Daniel Haskett
    November 14, 2007 at 10:18 am
    Hey Dan,
    Thanks for your help, sorry Im still gradually getting to grips with expressions. i tried to use what you said and this is what the expression looks like —
    thisComp.layer(“ski dust.psd”).transform.position.valueAtTime(t);
    temp = thisComp.layer(“SKIER FINAL”).transform.position;
    [temp[0], temp[1]+effect(“Slider Control”)(“Slider”)]
    it doesnt seem to work, im sure ive done something wrong. the layer ski dust.psd has its brush position linked to the position keyframes of SKIER FINAL…ive set a marker but still nothing.
    any help would be greatly appreciated!
    thanks
    dan
  • Dan Ebberts
    November 14, 2007 at 2:13 pm
    I guess I don’t understand what you’re trying to do. If you applied this expression:
    thisComp.layer(“SKIER FINAL”).transform.position.valueAtTime(t);
    to the brush positiion and create the marker on the layer with the write-on effect, it should do what I thought you wanted.
    I’m not sure what you’re doing with this piece:
    Dan
  • Daniel Haskett
    November 14, 2007 at 2:57 pm
    hi dan
    yeh that works better, the second section was so that i could change the x and y co ordinates – i was using a slider control for y….is there anyway this could be incorporated into the expression?
    cheers
    dan
  • Dan Ebberts
    November 14, 2007 at 3:52 pm
    If you want to be able to offset the write-on effect in the y direction with a slider, you could do it like this:
    s = effect(“Slider Control”)(“Slider”);
    thisComp.layer(“SKIER FINAL”).transform.position.valueAtTime(t) + [0,s];
    Dan
