Activity Forums Apple Motion How can you make a camera sweep around a fixed point?
  • How can you make a camera sweep around a fixed point?
    Posted by Gareth Randall on May 18, 2010 at 8:55 pm
    I’m trying to make the camera sweep in a circle while remaining fixed on a specific point. I’ve pretty much got it working, but I have a couple of questions.
    This is the image I want to sweep around:
    Specifically, I want to sweep in a circle while keeping the centre of the red circle (which is the anchor point of the group) in the middle of the frame. This shows how the camera is positioned:
    From here, I just dragged the anchor point parameter of the group onto the camera. By animating the Y rotation parameter of the camera, I can then track 360 degrees round the map keeping the red circle in the middle of the frame.
    This seems like a pretty straightforward issue, but I was wondering if there are any better/smarter ways of achieving it that don’t depend on matching the anchor points of the camera and the object you want to keep in frame?
    I ask this because matching the anchor points forces the camera to maintain a set distance from the image. Unless I’m missing something, once the points are matched you can’t move the camera in Z-space because then you will no longer be sweeping around a fixed point, so you can’t zoom in or pull out during the sweep. You can scale the image up or down to give the impression of the camera moving in Z-space, but that’s obviously not an ideal solution.
    Gareth Randall replied 16 years, 3 months ago 2 Members · 2 Replies
  • Mark Spencer
    May 18, 2010 at 9:00 pm
    Very good approach. And while true that you can’t move the camera along its z-axis, you can achieve what you want by changing either the Scale or the Angle of View of the camera.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Gareth Randall
    May 18, 2010 at 9:08 pm
    D’oh, of course, you can change the scale of the *camera*…
    *slaps forehead*
    Thanks again, Mark 🙂
