Activity Forums Adobe After Effects How can you decide the order Vector Paint strokes animate on?
  • How can you decide the order Vector Paint strokes animate on?
    Posted by Daniel Haskett on November 7, 2007 at 2:35 am
    Hi there
    Say Ive written a name using vector paint…when i chose animate strokes, it animates them all on at the same time….how can you decide when they animate on, or is this not possible?
    thanks!
    dan
    Erik Pontius replied 18 years, 10 months ago 3 Members · 2 Replies
  • Jens Enqvist
    November 7, 2007 at 8:00 am
    Look for Shift-Paint in the manual.
    There are different modes for recording paintstrokes painted while pressing the shift key. It is selectable through the VP context menu and the Comp view tool twirl thing.
    Or, you can change stroke start time using (keyboard shortcuts) copy-paste (not sure about cut). Unfortunately it is no longer possible (CS2, CS3) to use the VP stroke inpoint and outpoint shortcuts for some reason (“[” and “]”).
  • Erik Pontius
    November 7, 2007 at 5:06 pm
    An alternative method, would be to write out the name using the pen tool to create masks on a layer. Then use the “Stroke” effect and click the option to do all masks sequentially.
    Erik
