Activity Forums Adobe After Effects How can you create the perfect corkscrew spiral in After Effects?
  • How can you create the perfect corkscrew spiral in After Effects?
    Posted by Unit_9 on July 31, 2007 at 10:51 pm
    I want to create a corkscrew spiral so I can animate an object along it, but how can I create one?
    Cheers! 😀
    Nick replied 18 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • Steve Roberts
    July 31, 2007 at 11:01 pm
    If you just want the layer to travel in a corkscrew pattern, create a null and parent the layer to it. Rotate the null, and the layer will travel in a circle. Move the null up, and the layer will travel up while rotating around, thus making a corkscrew.
    Now … if you want to see the corkscrew, I believe your only hope is Trapcode’s 3D stroke, but I don’t think it does corkscrews. Maybe Zaxwerks Invigorator could do it.
    This could be yet another example of trying to push AE beyond its 3D limits.
    Anybody else?
  • Steve Roberts
    July 31, 2007 at 11:04 pm
    Wait — you could also fake a spiral by making a series of diagonal lines on a very long layer, and applying CC cylinder to that layer. The spiral won’t be a tube, but a strip.
    Google “Maffitt” and “spiral” to find the tutorial.
  • Craig Wall
    August 1, 2007 at 12:29 am
    I get the impression this user isn’t looking for a 3d corkscrew but a motion path shaped like a corkscrew.
    If I am correct I believe Illustrator has a built-in corkscrew shape somewhere. If you snagged that path and pasted it in as your motion path—then animated the scale of the object over time and perhaps embellished with auto-orient along path…
    ….would that work for you?
  • Colin Braley
    August 1, 2007 at 5:46 am
    That’s really a funny coincidence, I created a spiral expression yesterday while waiting for a render to finish. Try this out:
    //begin expression
    //Expression by Colin Braley
    //Modify these first few variables to change the effect
    centerPoint = [360 , 270];
    beginRadius = 25; //pixels
    endRadius = 100; //pixels
    startTime = 0; //seconds
    endTime = 3; //seconds
    howManyRings = 3;
    clockwise = false;
    //if you want the spiral to spin the other way make clockwise = false;
    t = time;
    if( time < startTime ) t = startTime; if( time > endTime )
    t = endTime;
    radius = linear( time , startTime , endTime , beginRadius , endRadius );
    theta = linear( time , startTime , endTime , 0 , (2 * Math.PI ) * howManyRings );
    if( ! clockwise )
    theta *= -1;
    x = radius * Math.cos( theta );
    y = radius * Math.sin( theta );
    [x , y] + centerPoint
    //end expression
    If you want to see how the created motion path looks, apply the expression to the brush position parameter of the write on effect to see it as a stroke. Also, if you set either of the radii to negative values, you can get some cool effects.
    ~Colin
    http://www.colinbraley.com
  • Colin Braley
    August 1, 2007 at 6:12 am
    If anyone want’s an .aep check out this link:
    Enjoy..
    ~Colin
    ~Colin
  • David Bogie
    August 1, 2007 at 10:52 pm
    Searching the forum might bring up an interesting project done last year (i think) using time displacement.
    The demo movie was lovely but I never could understand the concept behind how the effect was done.
    bogiesan
  • Unit_9
    August 29, 2007 at 11:23 am
    Hi Colin – this is great – thank you!!
    Is there any way I can add easing to this expression?
    And also, how can I cue expressions? Like how could I add another position expression once it has completed this one?
  • Nick
    November 21, 2007 at 6:48 pm
    Pretty cool stuff!
