Activity Forums Adobe After Effects How can you animate dot wave made in illustrator (.ai or .eps) in after effects
  • Eric Santiago
    February 8, 2024 at 11:26 pm
    Stardust has a particle generator template similar to this.
    Great plugin for AE.
  • John Cuevas
    February 9, 2024 at 4:13 pm
    If you have access to trapcode form you can create and do this in a snap. If not you could fake it by placing those dots in a precomp and a mixture of “distort” effects applied to them, like turbulent displacement, bulge and so on. They won’t be moving truly in 3D but you could probably get a look pretty close.
    Otherwise, it would probably be possibly with some serious expression work. Something that moves 1 dot in all three axis and then near dots look at that dot for cues on how to follow, but that’s a level of coding beyond me.
