Activity › Forums › Apple Final Cut Pro Legacy › How can we do realtime FCPro output through iChatAV in Tiger like Apple did at NAB?
Posted by Jb on May 1, 2005 at 11:17 pmUnfortunately I missed Apple’s NAB press event showing off Tiger/QT7 H.264/iChat AV/FCPro 5.
However, I’ve read (https://blog.millimeter.com/index.php/2005/04/18/apples-press-conference/) and heard (from other reputable sources) that they had the editors from the TV show “Scrubs” in an on-line chat while a REALTIME FCPro window played in the center window. They had REALTIME collaboration with the ability to change clips on the fly while everything played back very smoothly. NOTE: This was not just an iSight infront of a Cinema Display but a true output of FCPro 5.
If I were there I certainly would have asked for the specifics of how it was done, but since I missed it, I thought I would post here as well as in the “Web Streaming” forum.
Coming straight out from FCPro would certainly be great and has been covered extensively in prior posts I guess but I’ve had a hard time finding these threads in the cow.
Fortunately, I have figured out how to do a “rookie style” of this with iChat AV using Panther and my DV converter (or DV deck), but not directly from FCPro 4.5. And certainly not as elegant as this NAB demo sounded.
I do know about showmacaster ( https://www.showmacster.com/ ) and highly recommend it for anyone how hasn’t heard of it. It’s a very cool app and gets me alot closer to what I need for realtime collaboration with my clients. However, the screen capture is very slow and when used with FCPro does not work as well as the NAB demo appeared.
I also know about H.264 and how it is integrated into the new version iChat AV and provides excellent picture quality. But the real question still remains…
How was this NAB demo done exaclty? And how will us users be able to do it when it’s all released so that we can benefit from all this cool stuff?
PS-A cow article on this would be ideal.
Thanks for the ear and any info you have would be much appreciated.
Joe E. Botana
[ e d i t o r ]THE BUTCHER SHOP
http://www.homepage.mac.com/zbutcher5/DP 1.25 G4/Panther 10.3.4/Kona SD/FCpro 4.5
Jb replied 21 years, 5 months ago 9 Members · 13 Replies -
Bob Woodhead
May 2, 2005 at 1:31 amAll I know is the method requires sending firewire out to a 2ND Mac for streaming.
Chris Fenwick
May 2, 2005 at 2:19 amhey JB… why do you call the technique of using a second mac the “rookie style” of streaming fcp thru iChat.
I’ve actually been using this technique since the introduction of iChat AV…
Of course, it requires that you have intellegent clients that use iChat.
I’ve actually done it while cutting a piece for Apple’s Science division.
I outlined how to do this on my VERY LOW TRAFFIC web site back in July 03
Anyway… I guess the cat’s out of the bag… next think you know producers will not travel to edit suites ever again…
Bret Williams
May 2, 2005 at 6:07 amI assume they just plugged the firewire output of one mac into the firewire input of the ichat mac. No magic there.
Michael Carlino
May 2, 2005 at 2:42 pmI just got an email from someone I talked with from apple at nab about the set up.
of course we know that the 2 producers have there own computer with i chat.
The editor has his own computer that he has running his I chat camera and the fcp program. He has a second computer tha that is set up to recieve the output of fcp and used as an ichat camera. Out of the computer that is running his i chat camera and the final cut program he is running dcd out dvi to s video into a dv converter. he is also running a second audio out line that can be digital usb etc into the dv converter.The dv converter is then pluged into the mac computer that is setup as the fcp output I chat stationHope this helps
Michael Carlino
Director of Operations
Imagineering Institute
http://www.imagineeringinstitute.com
mike@imagineeringinstitute.com -
Billgilman
May 3, 2005 at 2:53 amFirst off, does anybody else feel like this is a major bait-and-switch for Apple to use this “AV Chat with the Scrubs clip” functionality in their hugely promoted and ultrahyped unveiling of their latest version of OSX, at a media-sharing hub like NAB no less, and then to find out that it’s a completely non-intuitive and expensive (a 2nd computer!) solution that’s geared toward the budget of an must-see-NBC show than a $129 upgrade?
Second, if I’m getting this right, the FireWire AV stream is already being used up by the iSight on Computer A, so I’d have to do a separate picture and audio stream out, have that converted to a second FireWire stream outside of Computer B, and fool Computer B’s iChat into thinking that that the FireWire AV stream coming in is actually another iSight (type) camera. Am I getting this right?
Anyone know if it’s possible to substitute the iSight’s AV stream on Computer A with my FCP output (replacing my face but maintaining audio) in software, so that it can all just be kept relatively simple?
Jb
May 3, 2005 at 3:03 amThanks you guys for the quick responses.
After a little bit of experimenting today (with Panther) I was able to finally get the output directly from FCPro 4.5 into iChat AV. And this is now working much like the NAB demo I presume. And if it’s not, it sure works the way an editor would want it to be, realtime playback from both the canvas and viewer windows.
Hella cool and once the quality gets kicked up in Tiger, this will be Apple’s response to AVID’s expensive fiber feed system.
Now obviously, if I wanted to participate in the chat on camera as well, I would simply use another computer with an iSight camera. In other words, my edit rig would be used to play the output from FCPro while another computer (e.g. Powerbook) would allow me to be on-screen for the video conference aspect.
A few of the previous posts mention:
“All I know is the method requires sending firewire out to a 2ND Mac for streaming.”
“I assume they just plugged the firewire output of one mac into the firewire input of the ichat mac. No magic there.”
I haven’t tried it this way but I believe you guys. Just like you said, I guess you would take the FWire output from computer 1 with FCPro installed and send it to a DV converter that would then just plug in to computer 2’s FWire input and Viola! The output from computer 1 shows up as video in computer 2’s iChat video window. However, that would mean using 2 computers just to get FCPro’s realtime output to show up in iChat AV, as well as, as a third computer to join the chat on-screen for the video conference aspect. Unfortunately, that’s an extra computer I don’t have.
Getting DV video into iChat AV hasn’t been the real challenge. We’ve all been able to plug a DV deck, camera or converter into our FWire port and have that video show up in iChat AV. Where it’s been a bit tricky is when you do it on a single computer and FCPro and iChat AV have to share the same FWire port simultaneously. This leads to many annoying “General Error” (FCPro) and “Your camera in use by another application” (iChat AV) errors. Maybe this is why others have simply sent the output to a second computer and avoided these headaches all together.
Having said that, now let’s get to the the fun part…
FCPro and iChat AV working together on the same computer to play a realtime output to iChat AV.
Eventually it would be cool if Apple just allowed FCPro to select iChat AV as an output and have everything work effortlessly/seemlessly together without the trial and error factor. But until then, this is what I’ve found to work best for my situation. And if you already knew how to do this please forgive the redundancy of this post but this is not an easy concept for the average user. So forgive my excitement of wanting to share this with everyone who wants to do the same but maybe didn’t really know how or where to start.
Hopefully, this post (which has now become more of an article-I apologize) will help those people by actually explaining the entire process involved. Or at least how it worked for me!
I have a DP 1.25 G4 with a Kona SD card and FCPro 4.5 installed. Note: Having a PCI capture card like the Kona or Blackmagic has really made this process rock. I believe since the I/O is a FWire capture card this scenario may not work as well or at all. You’ll have to try it for yourself.
Anyway, my Kona’s SDI output is being converted to S-Video while it’s audio is converted to RCA audio. This can be done with many types of equipment but I use an Extron SDI-AVR 100 for the video ( https://www.extron.com/product/product.asp?id=sdiavr100 ) and a Behringer SRC2496 for the audio
( https://www.behringer.com/SRC2496/index.cfm?lang=ENG ).Those converted outputs are then sent to my JVC HRDVS3U Mini-DV/S-VHS combo deck’s analogue inputs. My deck then converts this into DV and spits it out through it’s FWire port. This could probably be done with any analogue to DV converter though (e.g. Canopus, etc).
I then took the deck’s FWire output and plugged it into my G4. After having a few problems with iChat AV I finally got it to recognize the FWire signal after installing the small app iglasses (https://www.ecamm.com/mac/iglasses/). This app may not be necessary but it quickly fixed my problems for $8 so I went with it. Now click on the green video icon and you should see iChat AV’s video input.
Now you can see anything that is being played through your deck/converter in iChat AV’s video window. If you have a PCI capture card (like my Kona) you have realtime desktop preview (RDP). So at this point, you now have RDP out to iChat AV. This is way cool because you can do anything you want now, use the quicktime QT player to play a movie or listen to a song in iTunes and it will all play in realtime in iChat AV.
But since we want to play out of FCPro, let’s move on.
Finally, I launched FCPro and loaded a few clips into my project. Here’s where the bonus of a PCI capture card really comes in. Now, anything I play in FCPro (from the viewer window or canvas) plays out realtime in iChat AV. The real tip is that you cannot use the default DV-NTSC easy set-up because that will conflict with iChat AV for the FWire port on you computer and cause FCPro to display a “General Error” message. So just select the appropriate easy set-up from you capture card (e.g. Blackmagic NTSC-DV for DV or Blackmagic NTSC-8/10 bit for uncompressed) and you’ll be good to go. All your clips or timeline video will now appear in realtime in iChat AV.
So there it is, and yes this is way too long. Again I’m sorry about that, but if this helps just one person appear cooler to their client, or saves an editor’s butt in a time crunch. This will have all been worth it!
Thanks you guys,
Joe E. Botana
https://homepage.mac.com/zbutcher5/PS-This was done in Panther but will hopefully work the same under Tiger. One can at least hope!
And if this is information overload, you can always check out ShowMacster ( https://www.showmacster.com/). -
Jb
May 3, 2005 at 3:04 amThanks you guys for the quick responses.
Thanks you guys,
Joe E. Botana
