Activity Forums Adobe Premiere Pro How can video be played in a color?
  • How can video be played in a color?
    Posted by Eric Harper on November 15, 2014 at 5:49 am
    I want to play a separate video clip in a still object in my video which is a constant. I have been doing this using the Track Matte Key.
    But the only problem with this I have other portions of the shot that cross over above the fixed object and when they do the Track matte is above them and the separate video clip plays on whatever is on top.
    To solve this I thought if it were possible I want to assign the separate video clip to the color of the still object (which is distinctly different from its surroundings) instead of drawing a Track Matte on the object in attempts to fill the object as best as possible.
    If anyone has any ideas or solutions please contact me at:
    EricHarper7@yahoo.com
    Thank You,
    Eric
    Mike Jackson replied 11 years, 9 months ago 4 Members · 3 Replies
  • Alex Udell
    November 15, 2014 at 1:04 pm
    Can you put what is your video bg above the fill in video. and on that bg video use a garbage mask and cut a hole?
  • Paul Neumann
    November 15, 2014 at 9:06 pm
    I’m not sure I understand exactly what you’re asking but that won’t stop me from suggesting a solution! Nest the composite and use it twice? Once below and then on top? Or invert your track matte and use that on the background footage on a layer higher up the stack?
    I think I’ve had this problem before, but I’m not sure we’re talking about the same thing.
  • Mike Jackson
    November 18, 2014 at 9:06 am
    Maybe I’m misreading this, but are you trying to make a Chroma Key?
