Activity › Forums › Adobe After Effects › How can this sort of a blur effect be achieved?
  • Tudor “ted” jelescu
    February 29, 2016 at 12:31 pm
    Duplicate the layer, pull a key using Luma to get the highlights, animate a vertical directional blur and add glow. Play around with transfer modes – work at 16 or 32 bit.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Daniel Waldron
    February 29, 2016 at 3:30 pm
    Also, check out this handy tutorial from here on the COW.
  • Eric Santiago
    February 29, 2016 at 5:52 pm
    Mask the area as well before applying any blurs.
    Sometime scaling the layer help (vertical in that case).
  • Joseph Boutilier
    March 1, 2016 at 2:44 am
    A directional blur is the simplest way to replicate that exact effect. However, it sort of simulates a type of lens flare; you might also research flares and the Video Copilot Optical Flare plugins if you’re looking to create multiple effects with that aesthetic.
