Activity Forums Sony Cameras How can this be?
  • How can this be?
    Posted by Greg Ball on April 25, 2012 at 4:15 pm
    My crew shot footage and interviews for 1 day on our EX1. I took the card and using XDCAM transfer,
    I transferred all of the footage into FCP. I gave the client a hard drive with all of the footage as well as the BPAV Folder. I wasn’t on the shoot, so I couldn’t identify if something was missing
    The client says that the last interview and some last B-roll shots are not there. Their editor says they are not in the BPAV file either. How can this be? The card was not full (SDHC card), and we’ve shot 4 shows since then with no problem.
    Any thoughts?
    Brent Dunn replied 14 years, 4 months ago 10 Members · 14 Replies
  • 14 Replies
  • John Sharaf
    April 25, 2012 at 4:25 pm
    Sounds like operator error – failure to roll! It wouldn’t be the first time this happened to somebody.
    JS
  • Craig Seeman
    April 25, 2012 at 4:31 pm
    Do you see the missing shots in FCP?
    Did you use ClipBrowser with CRC to copy them?
    Can you look inside the BPAV to see if just some parts of the file structure is missing?
    I always keep a complete copy of the BPAV for myself when delivering camera masters to a client.
  • Greg Ball
    April 25, 2012 at 5:02 pm
    Hi Craig and John, thanks for your replies. John I would find it hard to believe that my crew would not shoot an entire interview where they start and stop between questions, and also would not shoot B-roll. It’s too easy to see the the EX1 rolling.
    Craig, No I didn’t keep the BPAV, but I kept all of the re-wrapped shots. I used those rewrapped shots to create a FCP timeline for the client so they could review the footage in prep for their edit. Those shots were not there. I’m asking for the hard drive with the BPAV file to be returned to me.
    My workflow is to take XDCAM transfer and convert all of the files from the BPAV folder. It’s always worked great.
    To your point about saving the BPAV file. That’s a good idea, but would I be able to rename that file so I can identify it as being the file from a specific shoot? Or would that cause a problem?
  • Ian Cook
    April 25, 2012 at 5:04 pm
    Did the recording maybe continue onto a 2nd card that you didn’t transfer?
  • Craig Seeman
    April 25, 2012 at 5:10 pm
    [Greg Ball] “Those shots were not there.”
    That’s not a good sign.
    [Greg Ball] “My workflow is to take XDCAM transfer and convert all of the files from the BPAV folder. It’s always worked great.”
    As per my seat belts explanation. If you don’t wear them it only takes a once in a lifetime fatal accident . . .
    It may have worked great . . . until now. You may never know the cause but using ClipBrowser with CRC on might have caught this (as would ShotPut). Basically there’s some change that the clips never copied and without proper software that uses some form of checking, you’d never know,
  • David Wheeler
    April 25, 2012 at 5:13 pm
    Never rename the BPAV folder itself, but you can rename the folder that contains the BPAV folder it to whatever you want. Your Browser and Transfer software will not recognize the clips if it does not see “BPAV” in the file structure.
    David Wheeler
    EX1R; EX3; FCP 7; 17″ MBP, MacPro Quad, Matrox MSO2,CS5
    dave@marcombiz.com
  • Ian Cook
    April 25, 2012 at 5:18 pm
    If BPAV had been renamed or otherwise modified it’s unlikely that Transfer would show any clips (not without a little surgery, anyway). I couldn’t agree more re all the suggestions to back up properly and leave BPAV intact but if it’s just a few clips either the TAKR folder wasn’t copied or else he may have rolled on a 2nd card without knowing it. A little more info from the receiving end (some screen shots of the directories and of Transfer UI) would probably shed some light..
  • Michael Palmer
    April 25, 2012 at 5:55 pm
    Does the interview end while in progress?
    If so perhaps the 2nd part of the file wasn’t rewrapped
    Good Luck
    Michael Palmer
  • Greg Ball
    April 25, 2012 at 8:34 pm
    To Ian… Nope we only used one card. That’s the weird thing. The camera operator left the card in the camera when he returned it to me so I would know which card he used.
    To Michael…nothing from the last interview is there. It’s as if they never recorded it.
  • Bill Griffin
    April 26, 2012 at 1:08 am
    This also happened to me several years back as I was using a Hoodman 16 gig SDHC card. The weird thing as the card said it was at 14.9 gig full, but we never could open the card. My Ex3 said it recorded and it did…but no media on the card.
    Bill Griffin
    HD Cameraman
    972-475-6870
    cell-214-802-9257
