Activity › Forums › Adobe After Effects › how can this be done easyily
Posted by Frank Sievert on April 14, 2006 at 10:55 amwhat i try to, is to show a complete movie from about 5 sec. to
appear as single pictures.Frank Sievert replied 20 years, 5 months ago 3 Members · 5 Replies -
Mylenium
April 14, 2006 at 11:32 amEach frame of a movie mapped on to a “card”? That would be pretty much work and indeed expressions seem the only way around this (time remapping and recyclings the cards over and over). Will have to give this some more thought, maybe I’ll have something for you some time later (if I don’t forget).
Mylenium
[Pour Myl
Kilbsy
April 14, 2006 at 2:36 pmMaybe you could export from video editing software as consecutive stills then animate the layers in 3d space to come to rest at equal intervals ie. every frame.
Mylenium
April 14, 2006 at 5:27 pmThat he could do, but eve nat just 5 seconds this would make 125 layers at 25 fps, which is already pretty much and slowing down everything. I would try to avoid that and adding some expressions and re-using the layers over and over would do that.
Mylenium
[Pour Myl
Frank Sievert
April 14, 2006 at 6:18 pmand the other problem is that i can-t change the source
footage after exporting it from the nle.
(and as you know: there are clients that wants to
change thinks 🙂
thanx for the input –
right now i-m worry about to do this keyframe by keyframe
so – Millenium – i count on you! :-)) -
Frank Sievert
April 14, 2006 at 7:38 pmthat can be a way:
It-s not quite the same, but
maybe i can work it out.
it-s done with particularhttps://rapidshare.de/files/18013175/final_2.mov.html
thank you for your input!
