Activity Forums Adobe After Effects How can I view just a single effect parameter for each layer?
  • How can I view just a single effect parameter for each layer?
    Posted by Dan Thompson on August 19, 2023 at 9:08 pm
    I have a layer with a stroke effect on it, how can I view only the “end” parameter of the stroke effect on the timeline? (In a way that will also let me edit the keyframes)
    Basically just like when you click on a layer and press T and it shows you just the opacity lane, I want to do the same but with the specific parameter I need.
    How can I do that?
    Dan Thompson replied 3 years ago 3 Members · 5 Replies
  • Leo Mazzei
    August 20, 2023 at 2:23 pm
    Hello, Dan!
    You may first select the property you’d like to isolate, then double-tap the S key in a quick fashion. This should isolate the properties you have selected.
    Best,
    L
  • Dan Thompson
    August 21, 2023 at 4:17 pm
  • Brie Clayton
    August 22, 2023 at 1:46 am
    Thank you for your solve, Leo!
  • Dan Thompson
    August 24, 2023 at 2:40 pm
    Is there a way to save my current setup after I’ve done this to all my layers?
    It seems like I need to do this every time I launch the project.
  • Dan Thompson
    August 24, 2023 at 6:42 pm
    Or maybe create a custom keyboard shortcut for this specific parameter?
