Activity › Forums › Apple Final Cut Pro › How can I use proxy and original media in the same project?
  • How can I use proxy and original media in the same project?
    Posted by Nik Voigt on January 22, 2017 at 12:37 pm
    I am working on a documentary film and I have a tone of footage from various cameras. Some of the footage plays perfectly in FCPX while other footage is too large. I have 8 TB of footage already so to save space I have only made proxies of the large 4K files.
    When I edit together these clips in the same project, however, I cannot watch them both. I have to choose whether the viewer plays back proxy or original but my project has footage that is both proxy and original.
    Is there a way to choose which clips play proxy and which play from original? I do not have the space to make proxies of 6TB of footage. I’m using FCPX 10.2.3
    Thanks for any advice!
    Gregor Myller replied 9 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    January 22, 2017 at 3:40 pm
    Nope it’s one or the other. Generally the workflow is- edit in proxy for best performance and then toggle to original for final exports.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Eric Santiago
    January 22, 2017 at 7:08 pm
    Duplicate the project and set one to proxy?
  • Nik Voigt
    January 22, 2017 at 7:59 pm
    Thanks for your reply. It seems a shame that you have to do all or nothing. Especially with large projects it is not very economical on space. You would have thought that there would be a way to chose which clips are played from proxy and which from original media.
    Cheers.
  • Nik Voigt
    January 22, 2017 at 8:01 pm
    But I want to edit both proxy and original clips together in one project. How would duplicating a project help? Maybe I’m missing something!
  • Noah Kadner
    January 22, 2017 at 9:32 pm
    Give a specific example- proxy files are a fraction of original files size and designed specifically to aid performance on lower specification Macs. How does mixing original/proxy reach that goal. Also you can easily and safely all delete proxies at any point during an edit and switch to originals.
    1 extra TB should hold proxies for several large projects at once and would cost less than $100. So not really getting why this is an issue.
    Noah
  • Robin S. kurz
    January 25, 2017 at 12:12 pm
    [Noah Kadner] “1 extra TB should hold proxies for several large projects at once and would cost less than $100. So not really getting why this is an issue.”
    Agreed. 1 TB can hold near 20 hours of Proxy footage. I edited a project with well over 1 TB of 2K footage. The proxies worked out to less than 150GB. Even the slowest, cheapest and oldest external USB3 drive performs well enough to play 5+ streams of it at a time. And you can get a 2TB one for as low as $70.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Gregor Myller
    January 31, 2017 at 9:37 pm
    I also have had good experiences with proxies for the rough cut using Multicam objects with 32 angles and 16 being displayed at one time while editing on a 12″ MacBook using a 4TB My Passport drive.
    I never thought an NLE could do that, as even Avid MC had problems displaying two DNxHD 120 streams from one 7200 RPM HDD.
