Activity › Forums › Media 100 › How can I turn a video clip upside down? I have Boris RED.
  • How can I turn a video clip upside down? I have Boris RED.
    Posted by Jerome Robbins on May 23, 2006 at 6:44 am
    I transfer old 8mm film and edit for family histories. One reel has torn sprocket holes that make the film visually chatter and it is really unviewable. I wound the film on a reel backwards and upsidedown. When I run it for the transfer it looks steady as the damaged sprocket holes are now on the other side of the feeder.
    The problem is getting the footage back to normal viewing. I use Media100 as my NLE, so I can reverse the footage. I have Boris RED. Is it possible to turn the footage upside down, which would actually be rightside up?
    Thanks for any ideas.
    jerome
    Michael J c replied 20 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Kieran Matthew
    May 23, 2006 at 12:04 pm
    Hi Jerome,
    Yep, flipping the image is easy with RED. Just lay your (reversed) clip on a timeline. Drag a RED comp or title over the top and hit edit. In RED, create a new video track, then use the rotation tools to correct the problem. Set an “X” tumble of 180 to flip the image. If you also need to flop the image, you can then use a “Y” Spin of 180.
    As it is a RED comp it will take a long time to render. After it is finished, you might want to “render range to bin” to fix the effect so moving/editing won’t lose the flip.
    Hope that helps
    K
  • Floh Peters
    May 23, 2006 at 12:15 pm
    [Jerome Robbins] “The problem is getting the footage back to normal viewing. I use Media100 as my NLE, so I can reverse the footage. I have Boris RED. Is it possible to turn the footage upside down, which would actually be rightside up?”
    An option would be to get Media 100 sw (e.g. the free trial version), which does this in realtime for playback, and if you want to render this effect it will be pretty quick. Or import your footage into RED, filp it there and render it through as a long movie for editing.
  • Michael J c
    May 24, 2006 at 5:25 am
    Yeah… I’d do this in M100sw… Obviously, the realtime effect is key, but even if you have to render I think it will be faster there than in Boris.
  • Jerome Robbins
    May 25, 2006 at 2:42 pm
    Thanks for the advice and steps to take. The 25 minute clip took 2 hours to render in Media 100 to reverse it and then 5 hours in RED to flip it, but it worked perfectly. This is a very powerful capability I have available to me and I am now aware of it.
    thanks,
    Jerome
    jerome
  • Jerome Robbins
    May 25, 2006 at 2:53 pm
    One other thing.
    I wanted to edit out a few seconds in several spots. When I try to plit a composition to cut out something I will lose the entire transition and have to re-render again.
    I guess I should have edited first and then treated each section as a seperate flip and render.
    any other comments on this?
    thanks!
    jerome
  • Floh Peters
    May 25, 2006 at 3:22 pm
    Here
  • Jerome Robbins
    May 26, 2006 at 12:17 am
    Thank you so much!! What a time saver.
    What I did in the meantime was mastered the program to tape then I digitized it back in to a bin, put it on the timeline, edited and then mastered back out to tape again.
    I noticed that it looked a bit dark and contrasty though. So, when I followed your directions and imported the original rendered file for editing, I compared the quality of the two versions. The edit from the original was much better so I mastered it to tape for the final.
    thanks again,
    jerome
    jerome
  • Michael J c
    May 26, 2006 at 5:41 pm
    Another trick is to drag that rendered file into a bin.
    Once in the bin select your settings and make sure you enable “source media file”. Then you can double click on that file name in your bin and it will open a finder window to the location of that file. Double click it again and it will highlight the file for you. Then you can do as floh says and drag that file right back into your bin and it is a real-time file for you to do with as you please…
    …just a quick way to find files you’ve rendered in your timeline.
