How can I turn a video clip upside down using Boris RED?
I transfer old 8mm film and edit for family histories. One reel has torn sprocket holes that make the film visually chatter and it is really unviewable. I wound the film on a reel backwards and upsidedown. When I run it for the transfer it looks steady as the damaged sprocket holes are now on the other side of the feeder.
The problem is getting the footage back to normal viewing. I use Media100 as my NLE, so I can reverse the footage. I have Boris RED. Is it possible to turn the footage upside down, which would actually be rightside up?
Thanks for any ideas.
jerome
