Activity Forums Adobe After Effects How can I trim my VideoHive template to only the first 8 seconds?
  • Cassius Marques
    February 25, 2016 at 9:13 pm
    go to the 8 second mark with the CTI and press “n”.
    Now hit crtl + alt + m. And render it out to your desired format with media encoder.
    Cassius Marques
    http://www.zapfilmes.com
  • Michael Szalapski
    February 25, 2016 at 9:26 pm
    Change your work area to only include the 8 seconds you want.
    Changing the length of your work area or changing the length of your composition will be covered in any good set of AE beginner tutorials. You will get frustrated trying to work with AE if you don’t go through something to get yourself a decent foundation. I recommend this set of resources: https://adobe.ly/AE_basics
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kevin Camp
    February 25, 2016 at 9:43 pm
    the most common way would be to move the cti to 8 seconds in the timeline and then type the ‘n’ key.
    or, when you render, click the render settings, click ‘custom’ in the lower-rightish and set :08.00 as the end…. but that’s a lot of clicks
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
