Activity Forums Adobe After Effects How can i to create an effects like this?
  • How can i to create an effects like this?
    Posted by Ali Khoshdouni on November 27, 2012 at 4:06 am
    I Have 2 shots that was linked bellow.
    In first shot camera is moving from left to right.
    In second shot camera has movement same as first shot.
    I want when camera is moving. boy from shot 1 change to that boy from shot 2.
    I want to create this effect without cut or disolve beetwen 2shots.
    First shot
    Second shot
    Ali Khoshdouni replied 13 years, 9 months ago 3 Members · 3 Replies
  • John Cuevas
    November 27, 2012 at 1:16 pm
    There is always going to be a cut or dissolve between the 2 shots, the question is how seamless can you make the transition and hide the fact that a cut took place.
    Do you have an idea of how you want to change from one person to the next? Do you want one person to morph into the other?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Tudor “ted” jelescu
    November 27, 2012 at 4:08 pm
    Unless you have a motion control rig that you used to shoot the two, there will never be a perfect match between them, therefore you can’t have one smooth move with just the character changing. There will need to be a morph between the two shots. Line them up, put the transparency of the one on the top layer at 50% and see at what point they are matching as far as framing and position- that will be the mid point of your morph.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Ali Khoshdouni
    November 27, 2012 at 10:42 pm
    Thanks John & Tudor.
    In fact i dont have any idea for transitions in changing character.
    I dont like morph. i need another transition but i dont know what transition realy i want.
    Is thist possible that first i try to object removal in mocha pro. then roto brush character from shot 2 and shot 1. then input characters in removed object footage. is it true method??
