Activity › Forums › Apple Final Cut Pro Legacy › How can I skip the annoying submit queue compressor menu
  • How can I skip the annoying submit queue compressor menu
    Posted by Ariel Brener on September 20, 2011 at 11:00 am
    Hi all
    How can I skip the annoying submit queue compressor confirmation pop-up menu.
    As shown in the attached pic
    I find myseld needing to press Submit Submit every time I use compressor
    sometimes because there is a lot of footage involved it takes time between the two.. so I loose conversion time.
    https://skit.ch/b38q
    John Pale replied 15 years ago 2 Members · 1 Reply
  • John Pale
    September 20, 2011 at 1:46 pm
    Two things. You should only have to hit submit once per batch. If you have an item selected, then only that item is submitted..so maybe that’s what you are doing,
    If you want to bypass the whole process, save your common conversions as droplets. Then you just drag your source files to the droplet and BAM! You are converting away.
    Search Droplets in Comprerssors help.
