Activity Forums Apple Final Cut Pro How can I see a multicam clip’s original timecode
  • How can I see a multicam clip’s original timecode
    Posted by Steve Sweitzer on May 3, 2014 at 3:28 pm
    I’m trying to read the original timecode from a clip within a multicam clip but the TC zeros at the beginning of the multicam when I create it.
    Longer story. I burn timecode into an interview clip and share it with a client. They pick their bites. Now I combine that clip with other camera angles to make my multicam but, after I lay the multicam into the timeline, I can’t find the bites the client picked using the original clip. Is there a way to see the original TC in clips once they are in a multicam clip?
    Jerome Raim replied 12 years, 3 months ago 2 Members · 1 Reply
  • Jerome Raim
    May 3, 2014 at 10:30 pm
    2 options:
    • Make a new multiclip in which you set the correct starting TC. copy all clips within one angle, paste into the new multiclip’s angle. Keep doing it angle by angle.
    • If you don’t want to make a new multiclip with correct TC, you can go into range mode (“r”) and hover your mouse over a clip to read its embedded TC.
    Jerome Raim
    Post-Production
    JeromeRaim.com
