Activity Forums Adobe After Effects How can I reproduce this animation?
  • Robb Davis
    September 28, 2015 at 11:27 pm
  • Kalleheikki Kannisto
    September 29, 2015 at 9:07 am
    I’d call that “animated mask reveal”.
    You would need a solid layer above the text layer, draw one or two masks per letter on that layer, and animate the paths over time to reveal the letters as if they were “drawn on”. The animation could be a simple rectangles that pull out or a more complex shapes that reveal the letters as if someone was drawing them (all letters at the same time).
    You would set the solid wiht the animated masks as the track matte for the text layer.
  • Robb Davis
    September 30, 2015 at 3:54 pm
    Thank you so much! I found couple of tutorials online similar to what I want to achieve. Thank you again!!!
  • Khaled Adel
    February 3, 2016 at 10:17 am
    You can done this only by using masks and text layer
