Activity › Forums › Adobe After Effects › How can I replicate this zoom in twist effect?
  • How can I replicate this zoom in twist effect?
    Posted by David Honan on September 30, 2014 at 5:00 pm
    Hi from not raining anymore 22 degrees C York Uk 🙂
    In After effects (Ive got CC but mm a bit of a rookie) I’d like to replicate the effect seen in this video https://www.youtube.com/watch?v=kVsbGEc1X1g @ 12 seconds. Really like how pic twists and jump cuts.
    Any advice welcome 🙂
    David Honan replied 11 years, 12 months ago 2 Members · 2 Replies
  • John Cuevas
    September 30, 2014 at 5:44 pm
    First, the picture is much bigger than the final composition, this is important so when you zoom/scale it doesn’t ter. The twists are achieved, by using rotation, scale and anchor point keyframes. The jumps aren’t even really jumps(you can see this playing frame by frame), but quick zooms, moves with a glow effect that ramps up and off quickly.
    This is all pretty basic stuff, so I would strongly suggest you check out: Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC)
    Learn After Effects CC
    Learn the basics of After Effects CC with tutorials by experts.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • David Honan
    October 1, 2014 at 9:02 am
    Grazie mille John 🙂
