Activity › Forums › Maxon Cinema 4D › How can I remove background?
  • How can I remove background?
    Posted by Kelum Jayasinghe on August 7, 2014 at 3:07 pm
    Hi guys,
    In the attached file I have a text animation and the blue background. I have a video on which I wanna place this text animation with fine lines. Is there an AE-friendly way in cinema 4d to render this text alone with a transparent background, so when I open the footage in After Effect I will only have text and the background video visible below it?
    7835_text.c4d.zip
    I dont like blue screen and chroma keying stuff because they do not do the job very well.. The edges are not fine…kinda feathered and the blue/ green traces remain…
    Please help…
    Cinema 4D ROCKZ!
    Kelum Jayasinghe replied 12 years, 1 month ago 2 Members · 2 Replies
  • Emir Bojorquez
    August 7, 2014 at 3:26 pm
    remove your background object, then go to Render Settings >> Save>> Alpha Channel and Straight Alpha.
    Then just select a format that supports alpha, like PNG or Quicktime Movie.
    Good Luck
    Imagination is the best tool…
  • Kelum Jayasinghe
    August 8, 2014 at 5:18 am
    It worked Emir….Thank you loads! 🙂
    Cinema 4D ROCKZ!
