Activity Forums Adobe After Effects how can i play swf properly in AE7
  • how can i play swf properly in AE7
    Posted by Eddy Alvarez on June 7, 2006 at 3:32 pm
    running into a headscratcher here.
    there is an .swf file that i am trying to import into AE7..and once its imported, it only reads 1 frame.
    the file setting are correct..matching frames rates and all, and still it just reads 1 frame.
    i’ve exported both from flash8 as swf and quicktime and same issues arise. any idea what i might be doing wrong?
    or is there an article that describes proper workflow regarding flash files?
    Ronaldo Montalvo replied 20 years, 3 months ago 4 Members · 3 Replies
  • Justin Productions
    June 7, 2006 at 4:03 pm
    I never imported a SWF file into After Effects before, but, when you import your .SWF file, in the Import Window, is there a check box, at the bottom, where it is written “Import SWF Sequence”? If yes, might want to check that. If there’s any; hope someone will give you a better answer.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Steve Roberts
    June 7, 2006 at 5:57 pm
    AE will only import the frames of the SWF. If the animation is script-driven, you’re out of luck.
  • Ronaldo Montalvo
    June 7, 2006 at 8:11 pm
    Xport the swf from quicktime pro as a quicktime movie, pick your codec, and then import to afx, should work for you.
