Activity › Forums › Apple Final Cut Pro › How can I move secondary audio clips around vertically without changing their timing?
  • How can I move secondary audio clips around vertically without changing their timing?
    Posted by Noam Osband on June 25, 2015 at 5:20 pm
    I have some secondary audio laid down, like room tone and crowd noise. I sometimes want to move clips vertically, close to the primary storyline, so I can better see how to adjust them in relation to what’s on screen. Is there a way, a button I can hold like there was in FCP 7, so that when I move it vertically, the timing of the audio element doesn’t shift at all? I’ve been looking into this online for the last 15 minutes and can’t find anything.
    Bret Williams replied 11 years, 3 months ago 4 Members · 6 Replies
  • Jerome Raim
    June 25, 2015 at 5:39 pm
    There’s no shift+click option like FCP 7.
    This is how I do it:
    1. Place the playhead at the head of the first clip that is selected.
    2. As a precaution, disable Scrubbing (S)
    3. Enable Snapping (N)
    4. Drag the clips vertically. They will snap to your playhead and an overlay will appear confirming that the clips are not moving (the overlay will display something like “+00:00.0”).
    Jerome Raim
    Post-Production
    JeromeRaim.com
  • Jeremy Garchow
    June 25, 2015 at 6:36 pm
    Select the clip (I hover over it and hit ‘c’).
    Hold shift.
    Drag the clip.
  • Bret Williams
    June 26, 2015 at 12:11 am
    But then all the other secondary clips shift due to the genius that is the magnetic timeline. Unless you use the p tool. Or, to get it out of the secondary, safest thing is cmd+shift up arrow. That’ll move it out of the secondary and replace with black without needing P tool.
    Side note- still drives me nuts you can’t use duplicate (option) along with shift to keep it in place horizontally. What’s up with that?
  • Bret Williams
    June 26, 2015 at 2:27 am
    I see it’s just audio so he’s probably actually talking about connected clips not secondary clips. I guess that threw me. In which case it’s the same button as FCP 7. Shift.
  • Jeremy Garchow
    June 26, 2015 at 3:49 am
    [Bret Williams] “What’s up with that?”
    Yeah. It would be nice.
    For now, ‘c’ to select, command-c to copy, option v to paste as conected, hold shift and drag to the stacking order.
  • Bret Williams
    June 26, 2015 at 4:58 am
    Geez that is insanely too complicated. Option drag works just fine. Usually it’ll snap to it’s location and you can watch the offset value just to make sure. But if we could option shift drag I could do it with my eyes closed.
