Activity › Forums › Adobe After Effects › How can i make this text effect
Posted by Mehmet Des on February 15, 2018 at 9:09 amHi,
Can u please help
I have tried all blur effects but i have not got same result as in this video.
https://www.youtube.com/watch?v=TkMYCpcOTFg
The problem is my blurred text doesnt seems clear enough at the right and left ends as in above video.Mehmet Des replied 8 years, 7 months ago 4 Members · 7 Replies -
Mark Whitney
February 15, 2018 at 2:00 pmThat’s pretty vague, and w/o being able to see your timeline one can only guess, but have you simply enabled the Motion Blur switch for both the comp & animated layers?
Mehmet Des
February 15, 2018 at 2:17 pmHere is my example
https://youtu.be/wVS6X8TxmlE
As you can see the text is too thin to be read at the edges in my example.
But in ad video the text is clearer at the edges. -
John Cuevas
February 15, 2018 at 2:20 pmThink you can do that with the Fast Box Blur set to horizontal only, and then compositing multiple layers of it on top of it self. Here’s a sample in CC 2018
Johnny Cuevas, Editor
ThinkCK“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Mehmet Des
February 15, 2018 at 2:45 pmThank you John, it looks very good.
Can u please tell me what is the different between “source text” and “source text 2” compositions.
And how can made this keyframe types on color? -
John Cuevas
February 15, 2018 at 4:29 pmThere is no difference from Source Text and Source Text 2. I just duplicated the layer and AE added the 2, if you click the Source Name at the top and change it to “layer Name” you will see they both come from the same asset.
The top layer, is just for the color change. It has a fill effect with 2 hold keyframes(select both keyframes and press Cntl+alt+H) so that it changes from white to red when the blur is done animating.
Layer 2 to 5 have the box blur applied to them. Rather than having keyframes on each layer, on layers 3-5 alt+click on Blur Radius then used the pick whip to layer 2 Blur Radius. Then you can just adjust the blur on layer 2 and it layers 3-5 follow.
Hope that helps
Richard Garabedain
February 15, 2018 at 4:46 pmTaurine is Bull semen…its in the drink in that commercial
Mehmet Des
February 15, 2018 at 5:16 pmThank you very much for showing such a detailed explanation to a novice like me. You are a very good person John.
