Activity Forums Maxon Cinema 4D How can i make this pattern in C4d
  • How can i make this pattern in C4d
    Posted by Chris Craig on May 25, 2016 at 9:15 pm
    Hi Everyone
    I have been asked to help create and texture a simple 3D model that uses this square pattern.
    Looking at it, I would probably create a triangle and extrude it, duplicate, rotate and aligned each to give an even distribution.
    Would this be correct? My level of skill in C4D is still relatively new
    Thanks a lot
    Chris Craig replied 10 years, 4 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    May 25, 2016 at 9:59 pm
    I would create a plane object and make it editable. Then go into polygon mode and select all polygons. Run the “extrude inner” function with preserve groups unchecked. That will give you the center polygons and they will be selected. Then just drag them down in the Y direction. Delete the plane object’s phong tag so you can see the sharp angles created.
    Then use a boolean object to cut out the desired shape.
  • Robert Troidé
    May 25, 2016 at 11:15 pm
    Yes, you’re right. Triangle, extrude, cloners, and bolean. No more.
    Here’s the c4d model. But it’s an easy one and it’s so rewarding to make it by yourself. You should try.
    10124_grid.c4d.zip
    RT
  • Chris Craig
    May 25, 2016 at 11:39 pm
    Thank you very much Robert.
  • Chris Craig
    May 25, 2016 at 11:45 pm
    Thanks Adam
