Activity Forums VEGAS Pro How can I make this effect/scene
  • How can I make this effect/scene
    Posted by Charly Olsen on August 16, 2013 at 5:57 pm
    Hello
    I am pretty new to Sony Vegas Pro, and I want to make a video with an effect like this: https://youtu.be/XQWvv-Yx4aE?t=2m21s (the map with the truck moving and the dots after it).
    My initial thought was to make each fram in Photoshop and then insert them in Sony Vegas, but is there a better/simpler way to do this? I also have access to Adobe After Effects, if that can be used.
    Thanks in advance!
    Charly
    Phil Peacock replied 13 years ago 2 Members · 1 Reply
  • Phil Peacock
    August 18, 2013 at 9:21 am
    Charly
    Firstly, if you are going to use a video to draw attention to an effect it is best not to use a video that is 46 minutes long! Or at least then refer to the time stamp at which the effect commences.
    Anyway, without watching the video itself, your brief description suggests you may benefit from using a free download called ‘Route Generator’ It is a great little program that is quite versatile once you familiarise yourself with its few controls. Very easy to use.
    Good luck.
