Activity › Forums › Apple Final Cut Pro Legacy › How can I make this effect to introduce somebody?
Posted by Glenn De wilde on May 18, 2009 at 11:51 amHi,
I like to know how I can make this effect to introduce somebody: https://www.hofleverancier.be
You can see the effect on the 7nd second.
Can anybody help me out?Thanks!
Glenn.Amir Abed replied 17 years, 3 months ago 8 Members · 10 Replies -
John Fishback
May 18, 2009 at 1:40 pmThat’s a chroma key. V1 would have the background, V2 would have the graphic behind him, V3 would be the guy keyed from greenscreen so he appears over the bkg & rear graphic and V4 would have the foreground graphic.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Jeremy Garchow
May 18, 2009 at 2:58 pmI would disagree with the chroma key. CHris is on to it, they simply made a still frame, rotoscoped the guy and moved him up in 2.5D space from the background and put a few different layers between him and the BG. You can tell, look at his left shoulder after the text goes by, you can see the mask line.
Jeremy
Amir Abed
May 18, 2009 at 3:36 pmThis is a very easy effect to do and it doesn’t use a green screen. You can’t do it in Final Cut you need to use Motion or After Effects. Make a 3 to 5 second freeze frame of the part of the video you want to use…drop it in after effects or motion then double the layer and using the biezer tool garbage matte the person on layer 2 after you cut out your person any video you put above layer 2 will cover up the person garbaged matted any clips you put between layer 1 and 2 will be behind the person garbaged matted. Experiment with differnt color effects textures and motion to get the look you want..good luck
Matt Sepeta
May 18, 2009 at 3:39 pmAgreed. I would make freeze frame, bring it into photoshop and put the subject on his own layer. Then make each word on a new layer, under and over the subject, respectively. If you actually spent 10 minutes on it, you should be able to pull it off twice as good as the example given…
Good Day
John Fishback
May 18, 2009 at 3:41 pmYou’re right. The guy’s a still and masked. If there are a lot of this kind of scene, it might be simpler to do it on greenscreen than all that rotoscoping – unless you like doing that.
John
David Bogie
May 18, 2009 at 4:25 pmYou’ve posted this same question in other forums so please go back to them all and close your threads by telling us how you solved your challenge.
It will be a great help to anyone searching for similar solutions in the future.bogiesan
Steve Eisen
May 18, 2009 at 5:11 pm“Queer Eye Effect”
https://www.lafcpug.org/Tutorials/basic_queer_eye.htmlSteve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Matt Sepeta
May 19, 2009 at 4:59 pm“You can’t do it in Final Cut you need to use Motion or After Effects.”
False. You can achieve this soooo easily in FCP! You just need a fundamental knowledge of Photoshop.
Now dont get me wrong, you shouldnt use FCP for this, but it’s possible and convenient.
“https://snowboarding.transworld.net/2008/08/19/zombie-boardshop-teaser/”
I did the titling at the end entirely in FCP and photoshop. Should have spent more time on it, but oh well, it was my first time.
Good Day
Amir Abed
May 21, 2009 at 10:40 amWhat I meant by you can’t do this in final cut is that in additon to final cut another application would have to be used also like motion or photoshop like you just said you did
