Activity › Forums › Maxon Cinema 4D › How can I make text pop out of this grid?
  • Darby Edelen
    June 2, 2014 at 3:08 am
    If you use the Custom Shader mode of the Shader effector then the UVW coordinates of the Shader are based on the UVW coordinates of the Clones. Try changing the W(UV)-Orientation value on the Transform tab of the Cloner. Depending on how your Clones are generated one of those options may or may not work for you (Y+ or Y- are likely).
    Alternatively you can use a Material with the Shader effector and use any of the texture projection modes (defined in the Texture tag).
    Darby Edelen
  • Adam Trachtenberg
    June 2, 2014 at 5:51 pm
    Another option would be to use a plain effector with falloff set to Source — in this case the source being geometry in the form of the letters G and H.
