Forums Adobe After Effects Expressions How can I make some random velocity of each object with random position?
  • How can I make some random velocity of each object with random position?
  • Byeong Han Kim
    July 2, 2022 at 12:12 am
    I try to make some falling objects, I can make random fixed position but I can’t make it move with random speed.
    here is a expression that i try.
    seedRandom(thisComp.layer(“Null 1”).effect(“rotation seed”)(“Slider”),true);
    var v =thisComp.layer(“Null 1”).effect(“spread”)(“Slider”);
    var x=[v,-v];//fixed y postition
    var y=[-v,-v];//fixed y postition
    gaussRandom(x,y)*(-time)*random(1,10)
    actually it move it well but when i add //*(-time)*random(1,10)// this part to move it, position of objects are fixed at one position and then start to falling down.
    can I get some any idea of this? I’m newbie of expression. So I want feedback of that poor expression too. Thanks.
    sorry for my bad Eng ;<
  • Filip Vandueren
    July 8, 2022 at 9:40 am
    Hi There,
    it happens because you multiply by time, at the beginning time=0, so everything is [0,0].
    You will probably need a random x,y position AND an random x,y velocity.
    or multiply by (-time-1)
Viewing 1 - 2 of 2 posts
Log in to reply.
