Activity Forums Adobe After Effects How can i make shadows more blue?
  • How can i make shadows more blue?
    Posted by Richard Garabedain on September 19, 2019 at 4:45 pm
    an object casts a shadow against a ground plane…how can i color the shadow more blue to match the background…i honestly cant figure out how to
    Greg Gesch replied 7 years ago 2 Members · 2 Replies
  • Greg Gesch
    September 19, 2019 at 11:10 pm
    Hi Richard. If you use either the Drop Shadow or Radial Shadow effects you can choose the shadow colour. Is that of any use? If you are using a light to cast it my instinct would be to try to make a track matte out of the shadow somehow – don’t know if that is helpful but it might give you a direction to think in?
  • Greg Gesch
    September 20, 2019 at 12:53 am
    Hi again, interesting conundrum. If you are using a light to cast the shadow:
    Duplicate your object and make it into a solid black/blue silhouette (don’t know what your object is so can’t assist there).Put it below your object layer – parent to original if necessary. In it’s material options set Casts Shadows ON, Light Transmission 100% – it will now cast a blue/black shadow.
    On your object layer set it’s Casts Shadows to OFF.
    Now play with the colour of your silhouette till you get a colour match.
    Should do it!?
