Activity › Forums › Square Box CatDV › How can I make an EVENT MARKER Search through catalogs?
Posted by Carla Vidal on January 18, 2013 at 1:40 pmis it possible? I can’t find the way to do it… thank you!!
Carla
Rolf Howarth replied 13 years, 8 months ago 4 Members · 3 Replies -
Brad Starkey
January 18, 2013 at 4:43 pmDo an advanced query. In the clip property switch it to Event Markers. That should do it.
Bryson Jones
January 18, 2013 at 9:48 pmGood one Brad. 😉
The thing is, remember that CatDV is an Asset Management system so it will return lists of assets, not markers.
There is no marker search capability that will return a list of markers that match the value.
However, you can quickly look inside the clip and see what the markers are.
This is why metadata schema design and workflow are so important in setting up a system. If you have to search for something constantly, make sure it’s in a clip specific field or that your media is divided up in a way that makes locating these areas possible.
In the end, I might add, don’t overthink it. If you’re coming from no DAM at all, just finding the clip is pretty amazing. If it’s something that important, perhaps it should be a subclip or some other division of the clip?
As Mr. Duggan taught me long ago in the swamps of Dagobah, it’s often the way you lay out your data as much as the tool that makes a workflow possible.
bryson
bryson “at” northshoreautomation.com
Rolf Howarth
January 29, 2013 at 8:33 pmIt’s true that the results of a seach will be the clips that match the query term, but CatDV remembers the last search phrase you looked for. If you bring up an HTML clip summary view it will highlight all occurrences of that term, including within event markers.
