Activity › Forums › Adobe After Effects › how can i make a spinning logo in after effects
  • how can i make a spinning logo in after effects
    Posted by Romeo Meier on May 11, 2009 at 8:06 pm
    i’m new to adobe after effects and i want to make a logo spin continuously can anybody tell me where to i begin, i had spent days to figure it out and there is nothing specific in the help files, i really want someone to explain this in baby steps please mention every click that i have to make in order to make this work.
    Richard Fleming replied 14 years, 7 months ago 3 Members · 3 Replies
  • Romeo Meier
    May 12, 2009 at 8:30 am
    1.) I have not much experience so far with 3d and effects i used to do little with final cut pro but even there i haven’t figured out all the possibilities yet
    2.) i don’t know what’s the best way of using it, i don’t understand what you mean with: ” Because you should never create an animation and render for final use within AE”
    3.) I’m just trying to figure out after effects and i’m looking forward to be able to do both 2d and 3d if you can please explain both ways
    4.) no… i could use a little help with alpha channel i never seriously worked with it and used it so rarely that i basically know thing about it and yes looping i think would be the best idea
    5.) i use a mac with OS X (tiger) and aftereffects works great with it.
  • Jeremy West
    June 29, 2009 at 7:16 pm
    Romeo,
    You probably have already found a sloution to this problem or gave up, but I do believe a novice can follow the instructions found here. It worked great for me and I have very little skill when it comes to animations.
    Check it out: https://www.adobe.com/designcenter/flash/articles/aft7at_3dinflash.html
  • Richard Fleming
    January 31, 2012 at 12:35 am
    Hey,
    Drag an AI, EPS, or alpha channeled PNG of your logo into the After Effects bin, then onto the New Comp icon. Highlight the clip in the timeline and press R to bring up the rotation settings, clicking the keyframe stopwatch on the rotation parameter you want (I’m assuming you want it on the Y-axis). Advance to the length of time you want the object to rotate one complete revolution, press N to set the end of the comp length, and enter the value 1 under the rotation parameter (where it says 0x). Then, slide that newly created keyframe a single frame past the out point of the comp, and Send to Render Queue. Now, you can set the video clip to loop and it’ll be seamless.
    Basically, alpha channels contain information about transparency. Meaning, if the background of a logo is supposed to be transparent, you need to save that transparency in a format that supports transparency, like PNGs, PSDs, TIFFs, and GIFs. JPGs don’t support transparencies. You do this because you can’t exactly save files in non-square formats. Is that clear?
    Here’s some additional info, but there are plenty of other resources too. 🙂 Best of luck.
    Kind Regards,
    Richard
    Richard Fleming
    Multimedia Specialist
    Creative Coop
    http://www.creativecoop.co
