Activity Forums Adobe After Effects How Can I Lay Bricks Over Another Scene?
  • Cali Foster
    December 29, 2021 at 10:12 am
    Attached are the Pink Bricks I am trying to make appear as though they are in the process of getting laid.
    Any help would be much appreciated : )
  • Graham Quince
    January 2, 2022 at 1:55 pm
    I feel like there is an eaiser way than the following, but I can’t think of it right now:
    • Create a new solid and add a Gradient Ramp, with the gradient going left to right
    • Add a second gradient and with this gradient running vertically, blend it with the original
    • Add a Mosaic effect, to create blocks.
    • Use a gradient wipe effect on your video layer
    If you’re not quite happy with this, it might be simplest to use masks and keyframe their opacity. But that’s more time consuming.
  • Cali Foster
    January 12, 2022 at 10:33 am
    Awesome thanks!
    I am going to learn more about gradient ramps and the Mosaic Effect!
    This is real chill!
    With this technique is there any reason why I would need to mess with Card Dance at all?
    Warm regards,
    Cali
