Activity Forums Adobe Premiere Pro How can I key video & stills through boxes?
  • How can I key video & stills through boxes?
    Posted by Thomas Imbrigiotta on March 3, 2012 at 11:10 pm
    I’m going to have a 4-box setup for an upcoming ad. That is, there will be 4 boxes on the screen simultaneously with four different stills/video playing within them. I need to be able to key frame the stills and reposition the video within each box.
    I’m quite familiar with the process in FCP. I would create a white box via Photoshop or a cropped video slug from within FCP and simply pull the video through with a luma key. This also allowed me to key frame the video/stills while maintaining the binding edge of the white boxes.
    I fooled around in Premiere for a bit trying to figure out an equivalent procedure. From other threads and my own experimentation the closest I can get is:
    1) Create a white box in Photoshop or Premiere (cropped color matte)
    2) Place the box above my video in the timeline
    3) Add a track matte key to the video track to pull it through my box
    However, when I do this I can’t key frame my video and/or stills b/c it pulls the matte along for the ride. The only work around I’ve found is to nest the content and then apply the track matte key to the nest (key framing moves to the original footage within the nest). This works but I’m kind of blindly setting my moves and then flipping back out to the nest to see the result.
    Is there an easier way to go about this (other than jumping into After Effects)? Any and all help is much appreciated.
    T.J. Imbrigiotta
    Envision Communications, Inc.
    Washington DC
    https://envisioncommunicationsinc.com
    Mac Pro
    2 x 2.26GHz Quad-Core Intel Xeon
    12GB RAM
    Blackmagic DeckLink HD Extreme 3D – Video
    ATI Radeon HD 4870 – GPX
    Mac OS 10.6.8
    Adobe CS5.5
    FCP7
    FCPX
    Chris Tompkins replied 14 years, 6 months ago 2 Members · 1 Reply
  • Chris Tompkins
    March 7, 2012 at 4:14 pm
    Nesting, Once you nest, say a still, in the Still sequence you can animate, key frame, etc. The put that comp. in the master comp and crop/position or animate as needed.
    AE is good for this too.
    Chris Tompkins
    Video Atlanta LLC
