Activity Forums DaVinci Resolve How can I Jump between shots away from edit points?
  • How can I Jump between shots away from edit points?
    Posted by Diego Burlando on July 4, 2017 at 4:02 am
    Does anyone know how can I jump between clips but not in edit points? I’m trying to check a XML timeline with the reference clip but jumping between frames away from edit points.
    Thanks.
    Diego Burlando replied 9 years, 2 months ago 2 Members · 2 Replies
  • Peter Chamberlain
    July 4, 2017 at 2:15 pm
    If you have an edit point selected, the previous/next will select edit points. If you have a clip selected, it will select the next clip.
  • Diego Burlando
    July 4, 2017 at 3:25 pm
    Thank you, Peter!
    But my question aimed to find a way to jump the playhead not between edit points but somewhat in the middle of each clip. I found that (edit points selected) up and down arrows and then Shift right arrow moves the playhead where I wanted.
