Activity Forums Adobe Premiere Pro how can I import and play 1080p at 60fps
  • how can I import and play 1080p at 60fps
    Posted by Dave Rogers on December 15, 2010 at 7:13 pm
    I have some footage shot at 1080p at 59.94 fps those are the setting son the camera and I have checked the file with mediainfo.
    When I drop it into premiere it says its 1080p at 29.97fps. If I tell premiere to interpret the footage as 59.94fps it then plays back at twice the speed.
    I have tried making sequences at 29.97 and 59.94fps but the clip plays double speed in both sequences.
    Thanks for any help
    Dave Rogers replied 15 years, 8 months ago 2 Members · 3 Replies
  • Mike Tomei
    December 15, 2010 at 8:30 pm
    Are you sure that it’s 60 frames per second, and not 60 *fields* per second (which is actually 30 frames per second)?
    What is the make and model number of the camera you used?
    Mike Tomei
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
    Adobe Production Premium CS5
    https://www.miketomei.com
  • Mike Tomei
    December 16, 2010 at 2:00 pm
    Looks like MediaInfo is incorrect. I’ve had it get confused with interlaced footage before too. According to the Sanyo site, that camera captures 1080i60, which is 60 *fields* per second, resulting in 30 frames per second interlaced. “1920 x 1080 (60 fields/s 12Mbps)”
    https://us.sanyo.com/Digital-Camcorders/VPC-HD1000-1080i-HD-Video-30fps-and-4MP-Photos
    Intel i7-930 2.8GHz
    12 GB RAM
    1 GB VRAM
  • Dave Rogers
    December 16, 2010 at 3:20 pm
    Mike
    Thanks a lot buddy,
    I look at mediainfo results with a sceptic eye from now on
    I appreciate your help
