Activity › Forums › Lighting Design › How can I hang these lights?
Posted by Barry Bishop on January 2, 2014 at 6:42 pmI have 2 Keno flow’s
a soft box from lowel
and a keylight
I would like to hang from the metal bar seen above?
I am assuming I need a clamp of some sort. Can one of you point me in the right direction?
Thank you.
Barry
Associate Web Producer/ Video EditorJoseph W. bourke replied 12 years, 8 months ago 6 Members · 10 Replies -
John Fishback
January 2, 2014 at 7:27 pmUse a c-clamp or you can uses scissor clips in the hung ceiling if the ceiling can support the weight. You’ll have to make sure the clamps have the proper stud for your instrument.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Mark Suszko
January 2, 2014 at 7:29 pmsomething like this will work:
look for gaffer clamps and C-clamp pipe clamps at Markertek and B&H photo&Video
Mark Suszko
January 2, 2014 at 7:30 pmThe sample John just posted is what we use in our grid for most of our lights… ours are 30-plus years old and still work
Barry Bishop
January 2, 2014 at 7:44 pmwill this hold a 4 bank keno flow light? any adapters I need?
Barry
Associate Web Producer/ Video Editor -
Todd Terry
January 2, 2014 at 8:32 pmIf I’m seeing your image right it looks like you have a couple of pipes from which you plan to hang instruments.
If that’s the case, the clamps that John linked will definitely work (the C-clamp, not the scissor clamp). Those are pretty much the industry standard for hanging an instrument from a lighting grid.
Yes, they will hang a Kino. You’ll need one per fixture. No, you don’t need any other adapters… PROVIDING that the pipes are where you want the instruments, at the height that you want them. If you want them lower (or the flexibility to make them lower) then you’ll want some grip arms to lower them (any 5/8″ stock from the hardware store will also work, doesn’t have to be a “real” grip arm). You’d need a grip head, too, in that scenario. But if the pipes are where you want them, you don’t need anything else.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
Barry Bishop
January 2, 2014 at 9:51 pm -
Todd Terry
January 2, 2014 at 10:07 pmWell, again, if those pipes are at the right positions and heights for where you want the fixtures, then you don’t need anything else… just the C-clamp with the attached baby pin.
T2
Todd Terry
Creative Director
Craig Alan
January 3, 2014 at 3:05 amAfter installing Mavericks I can’t see the embedded picture of the original post.
BUT I would not forget safety cables for each lamp. and the clamps as well.
https://www.bhphotovideo.com/c/search?Ntt=saftey+cable&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
except for back lights that are difficult to get out of shots or for lighting a green screen or other back ground, I really prefer using lights (particularly Kino Flos) on floor stands like a baby jr. Climbing up to the grid to make adjustments or moving them to a new location is kind of a pain. But if they are mounted absolutely where you want them then it’s certainly nice for a permanent set of some sort .
Mac Pro, macbook pro, Imacs (i7); Camcorders: Panasonic AG-HPX170/AG-HPX250P, Canon HV30/40, Sony Z7U, VX2000, PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
Joseph W. bourke
January 5, 2014 at 2:59 pmBarry –
You owe it to yourself to get a quick education in the world of grip equipment:
https://www.msegrip.com/product/hardware/clamps.html
https://www.macgroupus.com/kupocatalog.pdf
There are so many solutions out there, some standard, some not, that you should have a handle on what the standard options are. It will help save you some money. I’m not suggesting you use these particular suppliers – just look at what’s offered.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Joseph W. bourke
January 5, 2014 at 3:03 pmOne more thing – the Dexel catalogue has hundreds of fixtures, and the beauty of their catalogue is that they have icons on every fixture page, showing just which connectors and accessories work with them. A very useful source:
https://www.dexel.com/Dexel.pdf
Joe Bourke
Bourke Media
